the mystery lever is your PTO lever, used to engage/disengage the PTO when you have your foot right down on the clutch. "ground" is where the PTO will turn in direct proportion to the speed at which the trator is travelling. You dont need to know about that - its not used much. Engine is the one you want to use for nearly all PTO implements. The PTO turns at the speed that the engine is running. the levers on your right. The far one is draft control, use it when your plowing, the rest of the time keep it all the way up in high position. The left lever has Position control which is used when you want an implement to hold steady, ie with a back blade. Thats the bit towards the back. The bit towards the front is for remote hydraulics. If you want to use these, ie for a tipping trailer, undo the "stop" thing, and put it right down the bottom. Now push the left hand lever right down to the bottom, now you can connect your hose. When you actually want to tip or whatever your using it for, pull the lever up, but dont go into the position control section. (ie only go half way up). To hold the trailer up you can go about half way. (ie a quarter of the whole distance) If you have any more wuestions post them here, or email me, [email protected] Ben
