V8 Massey,s
kirkC
09-04-2004 07:28:02
Hello,
I like V8 masseys , and Ive heard nothoing but flak from people that either dont like them,
or just want to spout off on the web pages,
I looked at a couple of them,and I was really Impressed by them, Especially that V8 emgine,(I love the sound of it,)!
Perkin,s did that engine right as alway,s
Is there any trouble spots in the tranny?
Like the Powershift system, or O ring,s inside the case?
A friend of mine with two 2775,s told me that they take alot of oil,
Dosn,t sound like to much of a problem,
Please get back to me on this ok,
Thanks again Kirk Conway,
Joe MN
09-04-2004 18:59:54
 Re: V8 Massey,s in reply to kirkC, 09-04-2004 07:28:02
We had a Massey 1155 for 16 years. It was a powerful tractor with good fuel economy, good ride and handling,good traction with duals and cast center wheels. The 1105,1135 and 1155 shared the same trans/rear end. Under extreme use(heavy pulling) that engine was strong enough to find the weak link in the drive train, the stub axle shafts. If they started to wear you could have metal filings in the trans fluid which then damage the power steering,3pt valves and multipower. Clean oil and timely filter changes are essential. I would love to have another one someday.
marlowe
09-04-2004 18:38:06
i worked for a massey dealer in the 2000 series years had first hand experience with the 2745 2775 2800 and 2805. they had tons of trouble with the 24 speed but NOT all was massey or the tractor a lot was owner missuse and that was when massey was having BIG time labor trouble and there was a LOT of in house sabotabe and i seen it parts missing and real poor quality control. the perkins 540 and 640 were good power plants but costly to keep up and repair and the 24 speed should not have been used because it was not tested well
kirk C
11-13-2004 16:15:28
 Re: V8 Massey,s in reply to marlowe, 09-04-2004 18:38:06
Hi marlowe,
I live in N kansas, and I hardly ever see
massey dealers around here,
I love the V8 perkins engines, and the 2700 series, their sweet,
i drove an 8 spd 2775 this mornin, without the powershift,
and it didnt want to go, or do anything much,
steering was really bad, couldnt turn the wheel
at all, and the hydro,s didnt work,
But I still want a 24 spd, and know how to run it so it dosnt break,
William Bos
09-04-2004 17:55:05
H,
I think he is referring to the 1155 ( and 2745 ) MF with the Perkins 540 V8 diesel in it. I would love to own one of these. I will keep looking untill I find one!! From what I hear they sound as awesome as they look. Especially the platform models with duals!!
Here is a link for you to check out!!
Link
Take care
Will
Way Up Here
09-04-2004 11:59:44
I'm not sure that "spouting off" is the same thing as voicing one's opinion on those V8 transplants. Personally, I see no harm in it as a novelty item. As far as value is concerned, it certainly doesn't make the tractor worth any more. Massy is one choice for the transplants because of the way the engine/clutch/driveshaft is mounted in the front tub of the tractor and no special adapter plate is needed. I had a buddy once who transplanted a V8 Chevy engine into a '78 Toyoto Landcruiser (originally a 6-cylinder inline gas) and he regretted it when he went to sell the Toyota, the transplant wouldn't sell. He was also disappointed with the torque in the V8, said it didn't compare to the original factory six.
someone
09-07-2004 05:12:25
 Re: V8 Massey,s in reply to Way Up Here , 09-04-2004 11:59:44
If you'd know Masseys, you would know that they have a few models with Perkins V8.
txblu
09-04-2004 16:53:33
I saw a V engined Massey at a gravel pit when I was running a rock bucket. Don't know if it was an 8 cyl or not but it looked like a factory job. Had duals and all. Guess it at 150 hp at least.
Mark
