MF burned alive
David(Ala)
09-03-2004 21:37:32
Old farmer had his equip shed burn last night. Lost a good MF 251xe (or something like this, a square bailer and a utility trailer. Question. Can a completely burned out tractor be repaired cost effectively? What damage to be aware of other than hoses, belts, wiring etc?
txblu
09-04-2004 16:55:08
 Re: MF burned alive in reply to David(Ala), 09-03-2004 21:37:32
Mine are insured for total coverage at the cost of $14 per year. Wise investment.
Mark
Peter, U.K.
09-04-2004 01:08:39
David,
Same thing happened to me a couple of years ago I lost three tractors, one of which was a newly restored MF 65 Mk1 diesel. The heat from the fire was so intense it had melted all the alloy components - fuel pump, etc. I stripped down the engine and found it was still OK, - I had expected heat distortion. I rebuilt the engine, replacing all the seals, etc and now it's working fine in another 65. The only thing you can do is strip the tractor down and see what you can salvage - you may be lucky, like I was. It's always worth a try.
Regards,
Peter.
