Battery goes dead
jjw
09-01-2004 09:54:44
Bought a 51 MH44. Been setting for 2-3 years. Dash switches were all rusted, got them to pull out finally. Ignition switch will allow tractor to start and stop. Light switch, not sure if it works cause the lights don't go on. Put a new battery in but it goes dead overnight. Could one or both of these switches be allowing a short of some kind to allow the battery to drain??? Or should I look elsewhere? jjw
marlowe
09-01-2004 16:38:55
 Re: Battery goes dead in reply to jjw, 09-01-2004 09:54:44
are you sure you got the battery in right?? from new on they are + ground 6 volt but you said you have a delco one wire alt. is it 6 or 12 volt and is the alt. made for + or - ground?? they can be made for eather way
txblu
09-01-2004 11:38:46
Anything's possible. Don't think ignition switch being on and only running ignition current would run battey down; if points happen to be closed. That's only 2-3 amps for 10 hrs is only 30 amphrs and you would/should notice a very hot ignition coil.
A sticking regulator could do it. The contacts are supposed to open when the priming current from the ignition switch is turned off, disconnecting the generator from the battery (so as not to run the battery down); so that would do it.
Other wise you have a short somewhere in your wiring to chassis. But that would/should promptly blow the fuse, if any, or burn the wiring insulation and you'd smell that.
The battery was the first guess but you eliminated that. So I'll go with the regl.
Mark
RussR
09-02-2004 05:54:21
 Re: Battery goes dead in reply to txblu, 09-01-2004 11:38:46
MH44; WHENEVER YOUR NOT TROUBLESHOOTING THE SHORT PROBLEM DISCONNECT THE BATTERY CIRCUIT AT THE BATTERY. CONNECT A V-O-M SETUP TO MEASURE 10 AMPS BETWEEN THE POSITIVE BATTERY POST AND THE + BATTERY CABLE (DON'T ATTEMPT TO USE THE STARTER AT THIS POINT). SWITCH ON AND OFF EVERY DO HICKIE YOU CAN THINK OF AND WATCH THE AMMETER DRAW.
IF THINGS ARE RIGHT YOU SHOULD SEE THE DRAW DIVE TO ZERO WHEN ALL THE DO HICKIES ARE OFF. KEEP ON SPARKING(NOT).
jjw
09-01-2004 12:18:54
Thankx Mark. But the tractor has a one wire alternator, so wouldn't the regulator be internal? jjw
txblu
09-02-2004 06:51:09
 Re: Battery goes dead in reply to jjw, 09-01-2004 12:18:54
Well you just hit upon an excellent source of your problem. The alternator is a 3 legged alternating current generator. The ac output is full wave rectified with 2 diodes per leg (6 total) into dc and fed to your battery via the large wire on the alt. If someone reversed the leads to the electrical system (battery during jumping usually) you will fry the 3 diodes which allow the alt to feed the battery, but don't let the battery bleed back thru the alt when the engine is off. They short out.
Take your alt off and go to AutoZone and have it tested. Bet you'll find the reg fried. They sell parts and rebuild for a very reasonable price.
Good luck.
Mark
John McPherson
09-01-2004 18:30:30
Reg should be internal, but check to see if there is 12 volts at the one wire leading up to the ignition switch.
If there is, the alternator was not wired correctly. Just relocate that wire to a point where the voltage is switched off when the engine is off, or install a 3 terminal oil pressure switch on a tee with your oil pressure take off point. The type used on a Vega is a good one to use because the two independant switched terminals are switched off when there is no oil pressure.
txblu
09-03-2004 10:50:23
 Re: Battery goes dead in reply to John McPherson, 09-01-2004 18:30:30
That misconnected wire could be the problem also.
Mark
