Change the seal / gasket in the front axel of the
Mikael
08-31-2004 14:11:35
Hi,
I wounder if someone could help me with how I should change the seal/gasket in the incoming axle to the gearbox.. ( I have 2 axles on the gearbox)
I assume that I should loose the 4 bolts.
Is it just to pull or should it be done in another way? Thanks for help or ideas!
TomTX
08-31-2004 15:12:01
 Re: Change the seal / gasket in the front axel of in reply to Mikael, 08-31-2004 14:11:35
Need more information: Model, Year, Power Steer or Manual. What are the problems? Is it leaking fluid now? This will allow someone to help you.
