MH44 Hydraulic Pump
cst
08-31-2004 07:55:49
I have a 51 MH 44 and I'am entertaining the idea of installing a front mounted hydralic pump running via a shaft from the front crank pulley. I would like to mount a snowplow on the front. Has anyone done this and if so where might you get the pulley and parts to create the drive mechanism. I have a similar system on a 52 Ferguson and it works great. I can build a mount for the pump and adapt the plow harness to the front of the tractor. Looking for store bought parts rather than cobbling something together.
Thanks.
slowsmoke
09-08-2004 05:16:27
 Re: MH44 Hydraulic Pump in reply to cst, 08-31-2004 07:55:49
massey 44's had live hyd. pump ran off the cam gear on dist. side of motor. I have one in the garage that I took off a puller
Alberta Mike
09-01-2004 04:25:34
The advantage that you're going to get of course is "live" hydraulics. There might be one disadvantage of the front-mounted pump though. I purchased a 101 Junior once that had one and the constant on-off load on that front crank nut can cause some problems. Most pumps (when they kick in) will be forcing that nut to loosen. The previous owner of this tractor pinned the nut in which worked but the pin hole was starting to oval somewhat from the pump force. I wonder how factory mounted pumps off the crank are set up on trucks, etc.
marlowe
08-31-2004 18:55:28
you will not find store bought parts but it's not real hard to make if you have the tools and some time
