Te20 miss firing when warm and dieing!
Sharon
08-29-2004 09:23:16
I have an old te20 and when it gets warm - after about 10 mins it seems to stop firing on all cylinders and then splutters and dies. If I let it cool down and restart it its ok. It's just had a new distrubutor but seemed ok just after that was fitted. Any ideas - it's taking about three days just to cut a smal field! - it does need tuning as the engine is racing a bit
John McPherson
08-29-2004 11:59:43
 Re: Te20 miss firing when warm and dieing! in reply to Sharon, 08-29-2004 09:23:16
It sounds most likely to be either the ignition coil or the condenser.
Replace condenser first to see if that corrects it, and then the coil and see if that makes a difference, as both items can test okay when cold, but when they get above about perhaps 120 degrees, clearances decrease, and is likely creating a short.
