Will any 12-volt alternator do?
DanL
08-27-2004 13:35:59
It appears the alternator on my MF-220 may have gone out on me. If I'm only interested in keeping the battery charged, can't I replace it with any 12-volt alternator that will push close the same rated current (15 amps)? This model has an alternator with the rectifier and regulator built into it. Shouldn't that also make it easier to find a suitable replacement?
Thanks,
Dan
janne
08-28-2004 05:02:32
 Re: Will any 12-volt alternator do? in reply to DanL, 08-27-2004 13:35:59
any 12 volt alternator will work, as long as you can make it fit to the mounting brackets. However, if you are not using much current while running, i suggest you get a regulator with not a very high charging voltage. I have noticed even 14.0 volts is a bit too much in summertime when i don't need lights, etc., and it tends to boil out the battery.
randy ,k
08-28-2004 00:08:43
I think the GM/Delco alternator would be your best bet on the MF-220 if it fits.I"ve never seen a MF-220 what is it a swather ?.We use the GM/Delco alternator on our MF tractors a 135 & 265.Hope that helps
DanL
08-28-2004 21:04:27
 Re: Will any 12-volt alternator do? in reply to randy ,k, 08-28-2004 00:08:43
Thanks guys. It turned out to just a blown fuse. Still, your comments are much appreciated.
The MF-220 is Japaneese-made two-cylinder diesel. This particular tractor is actually a Hinomoto 240. I was just lucky to find out that the company produced it under several different names.
