JR#1
08-25-2004 09:16:26
Have complete front end, with steering box, hubs (with good bearings and caps)in good shape. transmission gears, bull gears, rear axles and housings, 1 rear 9 bolt hub, bell housing, shifter assembly, belt pulley drive (no pulley) pto shaft, drawbar assembly, grill (good for parts, straight and solid, but missing a few bars), block, crankshaft, camshaft, connecting rods, head, manifold, lifters, oil pan, breather assembly (very nice and complete), gas tank, operator platforms, 1 rear weight, starter and generator (need rebuilt - good cores), steering column, steering wheel (straight but needs redone), water pipes, breather tube, driveshaft, pto shaft coupler, water jacket plate with breather tube (very nice), flywheel with ring gear, input shaft, and probably a few parts i forgot. i am in central missouri. thanks and let me know if i can be of more help.
