Masssey Harris 33 ?
jdjack
08-23-2004 13:20:52
What does a Massey Haris 33 weight, with wide front, 2 or 3 point. and how much horse power did these come with from factory. Don't know alot about these. Have chance to buy one don't know what to look for. Know that one of the brakes don't work, something is broken.
Thanks for the help.
Bruce C
09-12-2004 17:30:46
 Re: Masssey Harris 33 ? in reply to jdjack, 08-23-2004 13:20:52
Nebraska TractorTest:Test No.509(October 1953).Serial Number Tested #33G1RF4960.Drawbar horespower 35.5;belt horespower 39.5.Tractor weight 3,820 lbs.Check condition of tin and tires.Check to make sure engine turns over and if possible here it run.Check to see if there is water in oil pan and also remove diff drain plug and check for water.From the data I have there was 11,607 of the model 33's made.There was no record of the number of diesel"s made.In the book I have it shows that accordig to former massey employees there was only 150 diesel's made.If you need more specs on the tractor drop me a line.I have seen one that a friend has and they are a nice tractor.
