Wiring voltage regulator
Don H
04-03-2000 19:09:38
I have a 1976 MF 130. The tractor will not charge. The generator puts out over 12 volts and the regulator seems to be OK-buttt there are 5 loose wires hanging loose below the regulator. There are 3 tabs on the bottom of the regulator-one marked bat (battery) one F (field?) and one line. where does the ammeter connect? Both wires are loose. HELP!!!!! !!!!!
Adrian
10-12-2000 10:27:09
 Re: Wiring voltage regulator in reply to Don H, 04-03-2000 19:09:38
I have a Luckytech P5MVP3 99E mainboard. The voltage regulator KV1083 (KD83) manufactured by
KILAR is broken and i can't find an equivalent for it. I would like to repair my mainboard because i don't
have money to buy another one. Please reply even if you can't help me. If you don't
know an equivalent at least please give me some
information about KILAR. Thank you for your cooperation. Adrian Rogoz
Zegn�l S�ndor
04-05-2005 15:14:11
 Re: Re: Wiring voltage regulator in reply to Adrian , 10-12-2000 10:27:09
? Voltage??? (+,-)???
Thanks!
