found metal filings in oil when changing oil
randy ,k
08-22-2004 22:09:17
found a small amount of filings when I changed the oil is that normal.its my dads tractor and he said there is always a little filings from wear is that right.because there Wasn"t many filings and it hasn"t been changed in 2 years .its a 135 MF diesel .
randy ,k
08-22-2004 22:27:02
 Re: found metal filings in oil when changing oil in reply to randy ,k, 08-22-2004 22:09:17
oh forgot the reason I checked the oil was because the oil pressure was high after I cleaned the air filter .now it uses half the fuel must of been plugged for awile.I thought it ran on fumes before now it must recycle them too because it"s been going for 3 days I raked 40 acres and even cut 10 acres using our 9 ft haybine and it still had a quarter of a tank.
txblu
08-23-2004 08:11:01
 Re: found metal filings in oil when changing oil in reply to randy ,k, 08-22-2004 22:27:02
Oil pressure indication got nuttin to do wid de air filter unless the tractor could only develop half rpm"s or sumpin lik dat. Musta been a fluke.
Shavings show up sometimes in some engines. Nowadays, they put magnets on the drain plug to capture the little critters oudda de oil
2 years on an oil change is a bit long in my book.
Mark
