shifting problem
johnb
08-22-2004 18:16:55
I have a Massey Freguson 35, late 50"s, that grinds going into gear and will not shift into PTO unless the motor is shut down. The throwout bearing seems to be moving back ok. The presure plate has a clutch inside it. Could it be that this is not releasing properly? Could some of the arms that release this clutch be bent or broken? Would like some thoughts on this before I go ahead and break the tractor in two to remove it.
ben uk
08-25-2004 11:35:08
 Re: shifting problem in reply to johnb, 08-22-2004 18:16:55
Its probably just a clutch adjustment.
My 135 did it, although not with the PTO.
Go to this link, a website of big deans, shows you how to adjust it.
Ben
Fred OH
08-23-2004 12:19:56
Try putting the hi/lo lever in neutral and see if it will go into gear that way. Have you used this tractor before? It"s got a two stage clutch that half way down should stop the pto and all the way down should stop the rear wheels too. The fingers on the pressure plate have adjustment screws on them...and they have so be set according to the book. I have heard of a clutch disc freezing to a flywheel and you have to pull them in forth gear and , well, kinda rough "em up to get it broke loose. Fred OH
parts man
08-22-2004 19:40:06
I think your owners manual should have directions for setting you clutch linkage. That should straighten it up for you.
