MF-135 Removing solenoid
greenengr
08-21-2004 15:28:26
On a 1974 MF135, is it possible to remove the solenoid without removing the starter? I ask because the one nut behind the starter could be hard to get at. Thanks for feedback.
Thomas
08-22-2004 06:04:35
 Re: MF-135 Removing solenoid in reply to greenengr, 08-21-2004 15:28:26
No, you could undo the bolts but to remove the solenoid you need to pull the drive gear on the starter into it"s engaged position to unhook the solenoid.
parts man
08-21-2004 21:03:25
If you have a 3/8 drive ratchet, use a couple of the 6" extensions to get you out past the end of the starter, it is easy to remove then. I"d tackle that nut first. ;)
