MF 25 hydraulics
Hastings
08-21-2004 13:41:15
I have a MF 25 with poor working hydraulics.It will pick up the arms in a jerking motion,and will raise them up to the transport position.Will not raise the arms off transport after"locking in".When the control handle is in the up position,the arms start to raise after aprox. 10 seconds,in this jerking motion. Oil level has been checked,filter changed,and the sump screen is clean. I did have to free up the bottom-most spool valve in the valve body,and according to the diagrams all is in the right place[.002 clearance between the arms and the spool valves] If one person stands on the arms while going up,and a second person gets on,the lifting motion stops,and the arms start to settle.There is no strength to lift in a steady movement or to hold a load. The engine needs to be at at least fast idle [1000 RPM]to do this ,there is almost no motion at all when idling. Any help would be appreciated, Hastings
Lila
03-09-2005 17:01:55
 Re: MF 25 hydraulics in reply to Hastings, 08-21-2004 13:41:15
Do you have repair manuels for the 25.
We are having problems with our hydrolics also. We cured the problem you have by cleaning the pick up screen.
Now we can't get the 3 point to go down.
