Would my 135 run my 605C baler short term if I ha
randy ,k
08-21-2004 10:12:41
wanted to know because I had bad luck this summer and fell behind on my haying because my 265 caught on fire and I couldn"t find fuel tank.I had to fix and use the old tank for now until I find new one.wanted to know just in case 265 were to break down again.
txblu
08-23-2004 13:09:13
 Re: Would my 135 run my 605C baler short term if in reply to randy ,k, 08-21-2004 10:12:41
Don"t know what a 605C baler is, but iffin it"s a square baler..... .....in a heartbeat.
Mark
Gerald J.
08-21-2004 17:55:45
The 135 would quite a bit overloaded, just like you would be trying to toss one of those round bales on the rack by hand with a pitchfork..
Gerald J.
Ray,IN
08-22-2004 21:35:57
 Re: Would my 135 run my 605C baler short term if in reply to Gerald J., 08-21-2004 17:55:45
I've powered my square baler with my MF gas 135 when forced to because the larger tractors were is use elsewhere. It will do the job- but you will have to use 1,2 or 3 gear, low range, to avoid overloading the tractor depending on how heavy your hay crop is and the size of the windrows. I do not recommend trying to tow a hay wagon behind baler, the tractor is too light.
randy ,k
08-22-2004 21:56:22
 Re: Would my 135 run my 605C baler short term if in reply to Ray,IN, 08-22-2004 21:35:57
the 605C is a vermeer round baler
