MF 180 pumps hyd oil out transmission gear shift
gwece
08-20-2004 12:39:53
HELP! A friend of mine has a MF 180 that all of a sudden starting pumping hydraulic oil out from around the transmission gear shift lever. Pumps the hydraulic oil out through the transmission reservior until all hydraulic power is lost. Oil is white and foamy. He drained all the oil from both hydraulic and transmission side and refilled with new oil. Went back to the field and in about 30 minutes it started doing the same thing again. Any advice is greatly appreciated.
Big Dean
08-20-2004 19:52:17
 Re: MF 180 pumps hyd oil out transmission gear shi in reply to gwece, 08-20-2004 12:39:53
I suspect it is the hose that runs through the transmission from the Multipower & auxiliary hydraulic pump to the front of the transmission has a small leak in it that is spraying oil at the shift lever. I have saw that happen a few times through the years.
