MF 135 PTO Disengages
nickO
08-19-2004 19:37:38
When using my 72" cutter on rough terrain the PTO (engine) will disengage frequently. Also does this on smooth terrain, but less often. Re-engaging is a bear and usually causing 'grinding'. Could this cutter be too much for this tractor, or maybe a mechanical problem ?
Big Dean
08-20-2004 19:40:55
 Re: MF 135 PTO Disengages in reply to nickO, 08-19-2004 19:37:38
Hi Nick That is usually caused by the detent spring not applying enough pressure to the detent. I have found this is usually caused by the pin that hold the shift lever on to the shift fork shaft being worn bad that lets the shift fork move in away from the detent in the access plate. Hope this helps If I can be of further assistance Email me
