Would like to know how to hook up fuel gauge for
randy
08-17-2004 23:21:39
there are two wires coming from tank .The wires were cut by someone before we got the tractor don't know how too hook back up. I checked the fuel gauge for any wires but they were removed.any help would be appreciated.
Tommy D6-8U
08-18-2004 02:59:12
 Re: Would like to know how to hook up fuel gauge in reply to randy , 08-17-2004 23:21:39
Randy,
One wire goes to sending unit center terminal; the other goes to ground. If the gauge is working, ground one of the wires (with switch on) and the gauge should go to full. This is your sender wire (+). The other wire will be grounded to one of the screws on the sending unit. You could also check both wires (with switch off) with an ohmmeter to ground; the ground wire should show almost no resistance. Hope this helps!
Tommy
