Problem solved
CityBoy
08-16-2004 17:52:22
Checked spark from #4 wire. Plenty of spark. Had new dist cap and rotor; so replaced them anyway. Put known good plug in #4; new plug that was in there still looked new. No change. Switched wires. No change. Finally pulled gas tank and valve cover. Clearances were all over the place. Set all valves to .013. Hooked up #1 and #4....so I could actually tell if #4 was firing. Started right up and ran smoothly on two cylinders. Put everything back together. Best it's run in several years.
