looking at 165- should I buy?
peter in Va
08-14-2004 05:43:31
I just looked at a 165 yesterday with a recently rebuilt 4 cyl gas engine. Everything looks like it works ok except for a bad shudder in the lift when it is raised. Shows 1900 hours on the meter and could be accurate (though I wondered why it needed a rebuild after only 1900 hours). Its more tractor than I need but it seems in really good shape and they are asking $5000 which is not much more than the smaller tractors are bringing around here. What is gas consumption like on this model? Any problem areas I should pay special attention to?
Any help would be appreciated.
Nebulas
08-19-2004 21:41:04
 Re: looking at 165- should I buy? in reply to peter in Va, 08-14-2004 05:43:31
My grandpa bought a new MF-165 gas in 1973, and we still have it today. It's a Perkins gas, which is not as common as the Continental, but has always been a great tractor. Growing up around our 160 acres, this is the tractor I lived on during crop season, and it's rarely disappointed. It'll outpull it's worth... easily pulling 3-14" plows or a 12" disc in southern Indiana clay hills. Until late 80s, this was our largest tractor for raising about 120 acres of corn and soybeans.
Ours has been rebuilt a couple times, even with relatively low hours for machine of its age, simply because it doesn't get run as much as it should... (since it seems sitting idle in the shed can wear more than pulling good ever day.) Even after the last rebuild, it likes to use a little oil on a good day of work, but never enough to cause alarm. Not sure about your lift concern. Ours will do that and howl a bit if the lift levers aren't set to properly bypass the hydraulic pressure when arms are being used vs. when spooled hydraulics are in use. Don't rule out a purchase simply because it was misoperation.
For that money, I'd have to ask a couple questions... which block does this one have? The Perkins is basically the diesel block... the Cont is basically the same block as in a 65 (which we also have had since new and always performs well.) Both are good performers in my experience, but I would say the Perkins is worth more.
Which transmission? Does the tractor have multi-power? This proves to be a major difference in verstility. The only problem we ever had with transmission was the main seal between engine and tranny... once clutch housing got doused once, never could keep a regular clutch from absorbing oil. If you're not putting a loader on the tractor, the most effective solution is to put in a brass button-type clutch, and the tractor will pull a lot better.
Overall, I would say the tractor is worth that money if you need one. You won't get beat, but I'm not sure you couldn't find a better deal. If it's in good shape, and has the above features, you'll be very happy. Any other questions, feel free to reply here and I'll answer as best I can.
Adam Paul
08-17-2004 12:40:27
The 165 is an awesome tractor! My dad has one, and it always works real good. Myself, I have a 65 and think it"s an awesome tractor too.
I"d see about trying to get it for a few dollars less though....
Adam
fergy
08-16-2004 19:14:28
The 165 is a good tractor. Owned one since 1967, pulled a 3-14 in heavy clay back then, it did a good job. Have had very little trouble that I can blame on the tractor. Put a loader on it later and it has proved a very handy tractor. It has good power with the continental gas engine. It's not too big for the small jobs and big enough for the occasional larger demand.
$5000 is not to much for one in good shape. I have seen them go for much more, especially when you get the city boys bidding.
Don-Wi
08-15-2004 05:51:01
Sounds like a good tractor, although I question why it needed to be rebuilt at 1900. Is it a perkins or continental engine? The perkins gas & deisels were rated for 52 hp where as the continental gas is only 48, but still a strong tractor. Ours is the continental, and it doesn't seem to drink too much gas. We also don't work it too hard so it could suck more. Ours has a loader on it so with being started almost every day in the winter for short periods of time, and every other day of the year, the engine is smoking a little at 3900 hours. Even that's a short lived life for this engine. The $5000 sounds about right for my area. Overall they are good tractors, and just a little bit more tractor than the 135's.
Donovan from Wisconsin
Keep looking
08-14-2004 19:35:00
$5K for a -GAS-? It might be an average price in some parts of the nation, as was mentioned, but near tobacco country...not so fast. Unless you are in a big hurry(mistake) to get a tractor I'd advise to keep looking. With the tobacco program sinking into oblivion there should be several tractors available in that price range that are diesel/newer models fairly soon. Keep an eye out for farm auctions and check fastline.com for comparable tractors. That lift sounds like it's going south, too.
rettchr
08-14-2004 17:58:26
I traded my MF165 gas on a Kubota M5700. The dealer later sold the 165 at auction for $5400, so your price seems to be in line with market here in WI. I traded it because I was unhappy with the closest MF dealer, and there were good Kubota dealers a lot closer.
The 165 was a good tractor, but it WAS fond of gasoline. Making hay, I use literally half the volume of diesel fuel in the Kubota compared to the Massey's gasoline. However, it always started easily, even in winter.
