mf 35 to 35x
nick uk
08-12-2004 13:35:01
Has anybody out there converted a 4 cylander 35 to a 3 cylander. I understand that the axle mounting casting etc is different,and that the bonnet side panel is longer on a 3 cyl. Can anyone go further than this and list all the differences/mods required
Laurence
08-14-2004 10:36:45
 Re: mf 35 to 35x in reply to nick uk, 08-12-2004 13:35:01
I recently did a similar conversion. Mine was from a 4 cylinder petrol/vo to 3 cylinder diesel. Do you currently have a 4 cyl diesel or petrol/vo engine? An experienced 2 hand parts dealer helped me with all the things that needed changing. I could elaborate more if required. Fuel tank changed (specific for round bonnet of 35 and 3 cyl diesel), clutch, possibly starter, radiator stays the same, front axle cradle stays the same. Possible air filter mod. Throttle linkage change and then had to make up fuel lines to fit. I think that was about it. The tractor goes very well now.
Phil Squires
08-21-2004 15:30:44
 Re: mf 35 to 35x in reply to Laurence, 08-14-2004 10:36:45
Do you still have your old petrol/TVO tank i,m looking for one
many thanks
Phil
William Bos
08-12-2004 17:33:51
Hi,
We are in the process of converting our MF ( FE ) 35 from a standard 23c to a Perkins. I got lucky and bought alot of parts on here ( Thanks Jack and PARTS MAN ) . From what I can see, the fuel tank is different because of the thermostart lines, and the injectors are in the top of the Perkins head. The front mount is different. ( Check the scrap yards and the Price a new one. Up here in Canada a new one ( a 135 Perkins mount is the same ) is cheaoer than a used one from the wreckers..... if I did nto get alot of parts for one price, i would have bought a new one..... .I may still to have a spare ) But from my measurementys the rad is the same. The LUCAS starter will work (* a heavier and better than the delco one in my opinion ) and you will have to buy a diferent clutch. While you have the tractor split change the tranny seals no matter the condition they are in.
Take care
Will
sibby(Aus)
08-12-2004 17:05:12
Nick, From memory fuel pipes, tacho turns opposite direction, cant remember if 3 cyl fuel tank was used, long time back. cheers, sibby.
