MF135 hydraulics on the bucket
Otis
08-09-2004 07:31:28
I have a MF135 continental gas (1965). I pulled the two handle spindle valve, which sits right in front of the seat, off to replace some o-rings becasue it was leaking hydraulic fluid from the control levers. After replacing the o-rings and pulling and cleaning the hydraulic pump filter I reassembled and filled with new oil. Well, now the 3pt will go up (slower than before however) and goes all the way up but wont stay up as it did before. It falls right back down...before the rebuild, it would hold even heavy implements for quite some time before very slowing allowing them to fall. Now the front bucket wont even go up. I'm wondering if I need to bleed the cylinders of air or something? I've run the tractor several times thinking the oil just needs to get pumped into the hydraulic cylinders but nothing is moving up front. Has anyone had any experience with this? Sure could use some pointers on this one! thanks, Otis
