MF135 stops running
JamesNC
08-07-2004 06:55:08
The last couple times i've mowed, my 135 gas quits running. It's like it runs out of gas. When i choke it it starts then stops again a few seconds laater. After 5 minutes or so it'll start back up and run for a while or stop again shortly after. You guys have been a big help in the past. Thanks. James
Big Dean
08-07-2004 10:04:06
 Re: MF135 stops running in reply to JamesNC, 08-07-2004 06:55:08
Hi James that sounds like a fuel restriction the most common place I have found this is in the tank valve. There is a screen in the top of the settlement bowl it yours has one also on the elbow where the line connects to the carburetor on the inside if it has not been removed. the restriction will let enough gas through & fill the carburetor bowl with fuel but not enough to run the engine when it runs out the excess gas from the bowl it will stop the engine. They will not start till enough gas runs into the carburetor. This problem is very common on most gravity fed fuel systems if there is any trash or rust in the tank. A coil will also cause that problem now and then but I have found that to be rare. Hope this helps
JamesNC
08-10-2004 17:44:53
 Re: MF135 stops running in reply to Big Dean, 08-07-2004 10:04:06
Thanks Big Dean, I think this will take care of my problem. I'm what you would call a Newby (a term from my Army days)to the tractor business but greatly enjoy my time outdoors working around.Heard and read alot about you on this board and appreciate all you give to us. Take care. James
