Part Needed
Chip Fontaine
08-05-2004 07:54:50
I am in need of a part for my MF 65 Gas engine. I don't know the part# but it sits between the rocker arm and the valve stem. It is about the size of a dime but thicker, flat on one side and cupped on the other. During an engine rebuild, one has become missing. There are eight on this four cylinder engine. Can anyone Help?
Oldfarmboy Jim
08-05-2004 11:23:16
 Re: Part Needed in reply to Chip Fontaine, 08-05-2004 07:54:50
Chip, It sounds like you are describing the stem cap. The in. and ex. valves each have a different one, so you can't interchange them if memory serves. Don't know where you can get the bits and pieces that you sometimes need without buying a whole set. I need a serviceable Z 134 3-5/16" piston. Not a whole set, not sleeves, just one used, but usable piston to replace one that has damage to the top edge. Good luck.
Chip Fontaine
08-06-2004 02:32:13
 Re: Part Needed in reply to Oldfarmboy Jim, 08-05-2004 11:23:16
The local dealer tells me that this is a discontinued part. If I can find some, I'll but a set. This is stopping me from finishing the project. I can't see any difference in the caps. They all look the same to me.
