MF 65 PTO
Don
07-31-2004 21:16:48
On a MF 65 the pto shift lever has three positions
Center is off up is marked engine speed pto & bottom is marked ground speed pto. What is the RPM of these to positions? Thanks
jason
08-15-2004 03:30:42
 Re: MF 65 PTO in reply to Don, 07-31-2004 21:16:48
your p.t.o runs at 540 revs while your ground speed p.t.o russ as fast as your tractors speed
Lee in MI
08-02-2004 15:38:15
Tom is right. The only thing I can add is, I once read some where that the ground position turned one revolution per 20" of ground travel.
TomTX
08-01-2004 06:03:52
The one marked engine is a standard 540 rpm at a set engine speed, stated in your Operator Manual and ususlly shown on the meter. The one marked ground speed, is used for some applications like raking with a pto driven side delivery rake, where the implement is really easy to pull and you can pull in a higher gear with lower engine rpm to save fuel, while the rake is running off your ground speed. Advice: get manuals for your tractor,real MF brand manuals, 3 of them: Operator, Repair, and Parts. Best money you will ever spend.
