MF AB-O-22 Disk Harrow
Halbert
05-11-1999 13:44:18
I have one of the above 3-pt, 24 blade disks. It is handy and does a good job, but some of the cast iron spools/bearings are shot. I would like to repair it but the parts from MF are outrageously expensive. I purchased one spool last year, I believe it was around $60, and used it along with some new bearing caps I picked up at an auction in a job-lot box of parts. I was able to rebuild one gang. I have a feeling the upper cap would be around $80 and the lower one probably $50-60. When you multiply all this by 8 for the whole disk, it doesn't make much sense. Do any of you know of a source for these parts that is more resonably priced. The part nos. are: spool--662048M2, upper half--662046M2, and lower half--662047M1. Thanks.
The Red Ed
04-02-2000 05:29:25
 Re: Re: CAN U I.D. THIS ???? in reply to Bob, 04-01-2000 19:06:11
Thanks for the reply, Bob.
I will try to get back over to his place with the digital camera next weekend. I'll either post straight at you or find someone to post to the board (I can figure out how to do it!!). I did look for paint color..... ..100% rust brown!!!
The steering shaft does lay flat to the world, beneath the hood. This causes the steering wheel to be at 90 degrees to the seat platform. The steering gear is completely beneath the hood in a bolster arrangement similar to the F type Farmalls. Thanks again, Ed
