MH-44 Leaking Transmission Input Seal
MH in Oregon
07-29-2004 16:18:36
Greetings! I'm sure one of you Massey-Harris fans is familiar with this problem: tranmission oil all over the 'tub' of the tractor beneath the input shaft to the transmission just behind the coupling from the clutch shaft. Is this a huge job to replace this seal, or will loosening the coupling allow enough room to remove the cover plate on the front of the transmission and get at the seal?
Thank you kindly in advance.
jerry
07-29-2004 19:24:14
 Re: MH-44 Leaking Transmission Input Seal in reply to MH in Oregon, 07-29-2004 16:18:36
bad news,if its the seal your talking about you have to remove the motor and pull the shaft that connects the motor with tranny to get to the seal.where are located in oregon i;, also in oregon.
MH in Oregon
07-30-2004 10:30:54
 Re: MH-44 Leaking Transmission Input Seal in reply to jerry, 07-29-2004 19:24:14
Hello Jerry,
Thank you for the information. I was afraid this was a huge job. Don't really relish the idea of engine removal to replace that seal, but it is a bad leaker. I'm located in N. Willamette Valley near Aurora.
Regards and appreciate your knowledge sharing.
jerry
07-31-2004 07:48:24
 Re: MH-44 Leaking Transmission Input Seal in reply to MH in Oregon, 07-30-2004 10:30:54
i'm in scappoose nw of portland if you need any help or if you want to sell your 44 [email protected]
MH in Oregon
08-03-2004 11:08:24
 Re: MH-44 Leaking Transmission Input Seal in reply to jerry, 07-31-2004 07:48:24
Hi Jerry,
Tried your email address at "[email protected]" in order to communicate with you in detail about the 44. Message came back as undeliverable. Please advise.
Thank you,
Randy
