MF/204 power steering problem
Dewayne
07-28-2004 19:08:06
My 204 becomes hard to steer as it heats up. The power steering fluid leaks into the crank case which I believe is due to a bad seal on the back gear. Recently, as soon as I start the tractor the reservior completely empties all fluid in a matter of a few seconds. Could this be leaking out the rear seal also? There is no obvious leak outside the pump. Any suggestions? Do I need a new pump, or do I have other problems within the power steering system?
parts man
07-28-2004 21:07:15
 Re: MF/204 power steering problem in reply to Dewayne, 07-28-2004 19:08:06
Put a new seal in the pump before the hydraulic oil ruins your bearings!!!
