Well, duhhhhh. I was just re-reading page one of the manual and it says... The "serial number" is stamped on a plate located on the right side of the tractor in front of the steering gear housing and just above the voltage regulator." Right where you said you found it. I have a '58 gas MF65 and my SN is on a plate on the left hand side of the dash. I do not have all the fancy fuel gauges, dash lights etc. and there is still room on the dash. The AD4-203 should be in the low 50's HP range. Do a web search on Nebraska tractor tests and search the 1960-1969 test range to find what they rated the tractor at. The MF rated the engine at 55 gross BHP (brake horse power) multi power is a "switch" lever (Big Light switch) on the lower dash, right side, just below the Water temp guage. Multi power will give you a speed boost in a given gear. If in 1st gear low range at 1500 rpm and low MP the tractor speed is rated at .93 MPH. Shifting into High MP the speed increases to 1.2 MPH. This is a shif on the fly ... no clutching is needed. The injector nozzles come down from the top. The fuel line from the injuction pump comes in to the rear of the nozzle. There is one glow plug, it is located just aft of the air intake line on the intake manifold. Hope this helps Jeff
