Carburetor Help
Todd
07-26-2004 19:17:05
Just overhauled my carburetor on a MF 202 Ind
and after I put it on it has an extremly high revs. Turning the idle screw down has not helped at all. Any suggestion on would be appreciated
txblu
07-27-2004 09:49:48
 Re: Carburetor Help in reply to Todd, 07-26-2004 19:17:05
I'm accusomed to Ford. Ford doesn't connect the throttle to the carb. It is connected to the gov. The gov determines the amount of opening the carb butterfly gets by the pressure the engine exerts on the gov spring (by centrifugal force caused by rpm's)and the amount of counter pressure caused by the throttle position.
Might look at linkage and make sure the gov is set up properly.
Mark
