PTO grinds when engaging
Jack
07-26-2004 08:55:59
We've got a Massey 255 with a 3 position PTO. It grinds pretty bad when trying to engage. Is this something that can be adjusted to fix?
Don-Wi
07-28-2004 21:07:59
 Re: PTO grinds when engaging in reply to Jack, 07-26-2004 08:55:59
Are you pushing the clutch all the way down? Have to do this on models w/ just live PTO. Otherwise check your adjustment. They are set up so 1/2 way down stops ground movement and you can shift. All the way down kill PTO, 3pt/ hyd pump. Etc...
Donovan from Wisconsin
kermit
07-27-2004 05:34:45
it could be the P.T.O. clutch.
CityBoy
07-29-2004 18:54:42
 Re: Re: PTO grinds when engaging in reply to kermit, 07-27-2004 05:34:45
Mine grinds a little (as in lightly) when engaging PTO unless I hold clutch fully depressed for several seconds before engaging.
Tried adjusting linkage which did eliminate most but not all the grinding. Have learned to live with it.
