Perkins A3.152 frost plug removal
William Bos
07-24-2004 11:21:33
Hi,
We are begining a rebuild of a Perkins A3.152 for Dads MF 35. ( swapping out 23c ) Are there any tips or tricks to easily remove the frost plugs ( including oil galley plugs ) sdo we can wash the block and all galleys before rebuild?
Thanks,
Will
mowr
07-24-2004 17:46:58
 Re: Perkins A3.152 frost plug removal in reply to William Bos, 07-24-2004 11:21:33
Sometimes bigger diameter plugs can be rotated in their bore by driving one side inward with a punch, then grabbing the side that's sticking out with channel pliers. Otherwise you can punch a hole in the plug (in the center of a small plug or the outside edge of a large plug) with an awl or a small, sharp punch, screw a sheet metal screw or lag screw into the hole, then use a couple of pry bars under the head of the screw to pull the plug out. Tip: when going back together, be sure not to put enough of any kind of sealer on the core plugs that it can clog an oil (or water) galley!
