Massey 50 Gas Won't Fire
Jeff
07-24-2004 05:01:37
I just repaced the points, and thought I set the timing right..... I set the points to 0022 on the lobe., next rotated engine to see marks for 6 BTDC, Rotor is approx at 7 oclock and points are closed and just about to open. Thought I did everything right but tractor will not even fire. It was running before my handiwork....
CH
07-26-2004 05:52:34
 Re: Massey 50 Gas Won't Fire in reply to Jeff, 07-24-2004 05:01:37
Check to make sure your points are closing with a multi meter, wouldn't be the first time someone bought a bad set of points.
Jeff Johnson
07-26-2004 06:59:27
 Re: Re: Massey 50 Gas Won't Fire in reply to CH, 07-26-2004 05:52:34
All fixed! Wire from coil was loose and after tightening, it runs like a champ.
