mf 165 loader
ss
07-23-2004 09:30:09
does anyone have any suggestions on front end loaders that would work for my mf 165. i beleive a mf 90 loader would but havent been able to locate one. i am in iowa, if anyone has another suggestion of a loader that would work or no where one if for sale please let me know.
thanks
lonestarjeff
07-25-2004 09:53:21
 Re: mf 165 loader in reply to ss, 07-23-2004 09:30:09
The older 700 series Ford loaders will fit the 165, if you're willing to weld up a belly bracket. It works great on mine.
If you have more heavy use in mind the MF236 loader would be a better(and more expensive) choice. Look on the sides of your bell housing for tapped bolt holes. The belly bracket on the 236/165 mounting kit bolts up from below(inspection cover)& from the sides. Not all 165's have the side holes. The bracket will still fit, but you loose some load capacity.
Jeff
ss
07-30-2004 05:14:53
 Re: Re: mf 165 loader in reply to lonestarjeff, 07-25-2004 09:53:21
do u know if a mf model 99 front end loader work with a mf 165.
any help would be appreciated
lonestarjeff
07-30-2004 08:03:32
 Re: Re: mf 165 loader in reply to ss, 07-30-2004 05:14:53
I would say yes. I was looking @ one this week on ebay, but could not go get it on seller's time frame. The frame is similar to the ford 700-series which is mounted on my 165 now.
The MF 99 I saw looked like the rear axle mount extensions were longer than my 701, if so, you could find or fabricate simple axle brackets instead of the more complicated belly bracket I used.
I think, like mine, it would be a great light to medium use FEL. I would try to find a more contemporary one to the 165(like a 236)for heavy
use. They have stronger & better load distributing mounts designed for the tractor.
Jeff
Phil in MS
07-23-2004 14:36:01
ss,
I believe the MF236 loader would fit your tractor. Also a Bush Hog 2400, 2425 and 2426 are matched to the 165. The first thing you need however is to look at the bellhousing on your tractor to see if the 4 hole bolt pattern is there. If you don't have that mounting spot it may be harder to find a loader. I just put a BH 2426 loader on my 255 and loaders off a 165 would also fit my tractor. Good luck.
