HP DIFFERENCE BETWEEN MF 35 AND MF135
will
05-10-1999 12:23:52
Can someone please help me out with the HP differences between the mf 35 and mf 135 gas tractors. Any help would be most appreciated.
Harold
05-11-1999 13:51:03
 Re: HP DIFFERENCE BETWEEN MF 35 AND MF135 in reply to will, 05-10-1999 12:23:52
Were all 135 gas the same, or did some use perkins 3-cyl and later ones went back to continental gas? I'm not sure.
Gerald
05-12-1999 19:16:01
 Re: Re: HP DIFFERENCE BETWEEN MF 35 AND MF135 in reply to Harold, 05-11-1999 13:51:03
Beginning in 1969, they used 3 cylinder Perkins gas. Did't go back to Continental until the 2235 best I can tell.
Gerald
Jack in NB
04-01-2000 04:19:00
 Re: Hey! Dean Matt I found my clutch problem! in reply to BILLY CATHEY, 03-31-2000 14:33:37
Hello Billy -
Lucky!
516 068 M1 is the current number for the 11" plate. Fits 35 thru 265.
When you put it back together, take your time. Check the pilot bearing. It's a 6203.
If you haven't got a manual yet (I&T is great, and a bit cheaper), hollar - I've got the assembly instructions written up.
Good luck!
Jack
