Fixin' my baby
paul
07-16-2004 08:48:49
Just got a 1975 MF135..my first tractor and she's a beauty..Only the tach works. How do I get the guages working? (She's a deluxe, not std) Fuses? New sending units?
Also, if I want to have her repainted, where do I get MF Red?
DP SOuth Wales UK
07-16-2004 11:19:53
 Re: Fixin' my baby in reply to paul, 07-16-2004 08:48:49
Hi,
Do you have a dynamo or alternator fitted? If it's a dynamo, you will have a control box under the instrument panel, either of which could be faulty that might be part of your answer. Failure of the fuel gauge may be due to a faulty sender in the tank. Open the fuel flap and put the coloured wire to earth(ground) and if the wiring's OK the gauge will go to full. To do this, run the engine at fast idle. Not sure of US spec but if you have electric oil pressure and temp gauges, do the same and you should see the gauges move. Check wiring for any breaks etc.
Cheers DP
