Harris Guy ???
msb
07-14-2004 19:24:48
Re; your reply on my ? about drawbar pin in transmission housing:" Suppose to have a groove cut in one end. The
flat strap, with two 5/8" cap screws holds the pin up into the case. A machine shop would be
able to duplicate, since the old iron fabricators
add shipping, which chokes purchase"---- Did you mean a step down(or shoulder) in pin size where the pin fits the strap ? tried getting the old one out today.Didn't budge it.Think about welding a piece on it and backing the strap bolts out to press it out.Thanks,bob
Harris Guy
07-15-2004 09:13:20
 Re: Harris Guy ??? in reply to msb, 07-14-2004 19:24:48
Yes, the pin has a shoulder, the flat strap has
a groove this shoulder fits into. Usually, once you remove the two 5/8" cap screws, you can turn
the flat strap, to loosen. Then, the pin either drops out, or you can turn, with vise grips, or
wrench. It does come out, no thread. '47 30, or
'56 Triple 4:same pin. Your pic w/two brackets
on the column throttle, appears back shop add on.
