MH 30 belt pulley
Randy
07-14-2004 10:34:11
Hello,
I'm looking to replace the oil seal on the belt pulley shaft of my MH 30. Can the outer bearing cage be removed by itself, or do you have to remove the entire unit? I removed the six bolts and the outer cage will spin but doesn't seem to want to come out. I didn't want to put force to it until I learned whether it should come straight out or not.
Thanks!
RandyN
msb
07-14-2004 13:36:20
 Re: MH 30 belt pulley in reply to Randy, 07-14-2004 10:34:11
Think its just the inner race of the bearing a little tight on the shaft.Try driving an old thin screwdriver in between the bearing quill and the housing and then tap on the end of the shaft with a soft faced hammer,while prying on the bearing quill.Parts book shows a seal collar on the shaft too.
