HP of MF65 Deisel
Rock
07-13-2004 20:01:51
What is the HP engine and drawbar of MF65 with the deisel engine? Would it be same as 165 with desiel? Also what is the diffrences in the 65 and the 165 with desiel engines?
Baarry_ID
07-16-2004 21:43:35
 Re: HP of MF65 Deisel in reply to Rock, 07-13-2004 20:01:51
What's the difference? The model 65 is MUCH cooler looking than the 165. Like the difference between a '52 Chevy pickup and a '66.
Bob
07-14-2004 17:49:30
Early 65 diesel:48.59 pto,42.96 drawbar.
Late 65 diesel: 50.98 pto,45.62 drawbar.
65 gas: 46.05 pto.
165 diesel: 52.42 pto,46.94 drawbar.
Jeff-oh
07-14-2004 15:25:52
The engine HP is 52 and the Drawbar in in the 48 to 49 range. To double check do a google search and nebraska tractor tests. Goto the universite site and look down the lists to find the MF 65 tests. They will be in the '58 to '74 time frame.
marty c
07-14-2004 15:57:03
 Re: Re: HP of MF65 Deisel in reply to Jeff-oh, 07-14-2004 15:25:52
a mf65 has 41 motor hp, and a mf165 has 53 hp. both of these examples are for diesel engines. gas engines are 8 to 10 hp less
Jeff-oh
07-15-2004 06:09:40
 Re: Re: Re: HP of MF65 Deisel in reply to marty c, 07-14-2004 15:57:03
From the MF service manual... not an aftermarket manual.
Page 1 section 2 "G-176 engine Specifications"
Engine Brake HP
Gasoline Engine 52 @ 2000 engine RPM
LP Gas engine
MF 165 --- 52 @ 2000 RPM
MF 65 --- 49 @ 2000 RPM
From Section 4 " AD4.203 Engine Specs..." page 1
Min Gross Brake HP
55 @ 2000 RPM.
Note these are the engine B.H.P.s the drawbar HP will be less due to system losses in the transmission etc.
Jeff-oh
