Throttle Plate???
Stan(PA)
07-13-2004 10:42:05
I need the throttle arm and plate for a Massey Pony. If that's not the right name, it's the little "bumpy" thing on the steering column, and the handle that rides on it to set engine rpm. I sure would like to find a new reproduction, but a used in good shape would be okay. Mine is worn smooth, and the handle has a groove worn almost halfway through it. I'd appreciate any leads on getting these parts. Thanks.....Stan
Ray-s
07-13-2004 19:25:49
 Re: Throttle Plate??? in reply to Stan(PA), 07-13-2004 10:42:05
HI Stan , On our Pony I took a small piece of metal and brazed it onto the throttle arm. Then used a 3 corner file and cut the grooves deeper in the casting part . I slid the casting down the steering column as I did not want to take a chance on disconnecting the arm at the bottom. Looked like it had 50 years of rust there. This is no good if you are trying for authentic restoration. Ray-s have picture if you want.
Stan(PA)
07-14-2004 06:15:54
 Re: Re: Throttle Plate??? in reply to Ray-s, 07-13-2004 19:25:49
Ray, I sure would like to see the picture. I'd kinda like to keep it as original as possible, but most important is that it works. My email is open. Thanks.....Stan
