MF 35 Canister oil filter stupidity
Fordfreak45
07-12-2004 23:47:03
I know this is a very stupid ?, but i have never messed with a canister oil filter before... had to split my MF35 w/perkins 3-152 diesel to replace the tranny input shaft seals and decided to change the engine oil while i was at it... had a friend helping take stuff apart and he took the old filter out... but didnt note how it went together
So, now i have a new cartridge, a new big o-ring that came with it... and a pile of stuff that i'm unsure about the assembly of (esp. the location of the small (about 1/2") o-ring?
also- how do ya get the canister to seal to the mount? the large o-ring matches the canister size, but it's very loose in the grove in the filter mount
and also, though the tranny and rear-end have 2 drain plugs, do they fill from the same place and share the dipstick?
Fordfreak45
07-13-2004 00:00:53
 Re: MF 35 Canister oil filter stupidity in reply to Fordfreak45, 07-12-2004 23:47:03
Never mind the oil filter problems- searched the archives and found this wonderful picture
and it seems that the o-ring that came with my filter is not the correct one for this engine
txblu
07-14-2004 07:19:35
 Re: Re: MF 35 Canister oil filter stupidity in reply to Fordfreak45, 07-13-2004 00:00:53
NAPA 1188 as I recall.
sibby(Aus)
07-13-2004 03:54:18
Tranny-hydraulics share same oil, fill by undoing plug L.H. side of gearstick and check dipstick on R,H. sideplate, give oil a little time to run through from rear of trans to back end and recheck level. Good Luck.
William Bos
07-14-2004 14:07:25
 Re: Re: Re: MF 35 Canister oil filter stupidity in reply to sibby(Aus), 07-13-2004 03:54:18
Hi,
you could do yourself a big favour and order a spin on conversion head for it, s you can put spin on oil filters on it instead!!
See you
Will
txblu
07-15-2004 06:05:23
 Re: Re: Re: Re: MF 35 Canister oil filter stupidit in reply to William Bos, 07-14-2004 14:07:25
thanks
