MF 1085---hydraulics
Make mine a Mas
07-12-2004 17:23:12
Is there an INTERNAL oil filter on a MF 1085 for the hydraulics , I know that there is an external cannister , but am told that there is one inside as well. If so , can it be serviced from outside without removing cab or splitting tractor.
sibby(Aus)
07-12-2004 21:25:23
 Re: MF 1085---hydraulics in reply to Make mine a Massey, 07-12-2004 17:23:12
Check under your diff housing, if you have a triangular plate held by 3 bolts, drain your rear end oil and remove the plate, there should be a strainer you remove and clean. regards, sibby.
