testing generators
jerry
07-10-2004 07:26:05
how do you test a generator to see if it is charging properly.using a volt/ohm meter,just installed new brushes h260 motor 44rc still not sure if working right.
Thomas
07-11-2004 14:08:07
 Re: testing generators in reply to jerry, 07-10-2004 07:26:05
I've always found that if you connect the two terminals on the dynamo to the battery and earth the case, it will run like a motor if OK. (obviously don't do this with the fan belt on, preferably off the vehicle). If it then fails to charge, chances are the regulator is at fault.
Chip S.
07-11-2004 06:01:10
Like Allan said, but if the voltage doesn't come up, it may be a bad regulator. With the voltmeter attached, momentarily ground the field post on the genny. If the voltage shoots up, your regulator is bad.
Allan C.
07-10-2004 20:50:15
To test a generator properly you need a volt meter and an amp meter. But.. if you only have a volt meter and it's a 6 volt , check the battery voltage before starting the engine. it should read a little over 6 volts, like 6.5. Start the engine and run at a fast idle, the voltage should come up to around 7.5 if it's charging. it may take a minute or so, if the starter took long.
