Massey Ferguson 35
Scott Russell
07-09-2004 12:46:51
I am having trouble with the lift on this tractor. If I push the lift lever all the way to the bottom the tractor will lift the disk very high. If I pull the lever up the disk goes to the ground. The only way to lift is to push lever all the way to bottom. Please advise.
Mike Wells
08-06-2004 12:27:41
 Re: Massey Ferguson 35 in reply to Scott Russell, 07-09-2004 12:46:51
I have placed a MF 35 deluxe Brochure in the VINTAGE Ads Gallery on this web site
it will give you info on the controls for your tractor and mutch more.
Good luck
Yankee in Tn
07-17-2004 06:46:53
Sounds like it is working backwards.Are you sure you don't have the draft and posistion controls mixed up? What posistion is the draft lever in?This may have something to do with your problem. You might check Big Deans website. Good Luck
