MF 255 overheating
Ray Frye
07-08-2004 09:19:30
I have a 1980 model MF255 with the 236 motor. Strong machine, but it comonly overheats when the motor is stressed by plowing or mowing. The engine cools readily to an acceptable temperature by allowing the motor to idle. I have replaced the thermostat/hoses and the only thing left is to replace the radiator (which I clean regularly). Has anyone else had this problem?
leland
07-10-2004 21:11:23
 Re: MF 255 overheating in reply to Ray Frye, 07-08-2004 09:19:30
Also are you using good engine oil some of the cheaper oil breaks down quick this can cause the engine to overheat also
leland
07-10-2004 21:08:25
try power washing radatior and oil coolers a lot of trash ends up in there had one do same thing
MF
07-08-2004 20:03:22
Have a 1976 255 w/203D, never had any overheating probs. Could be...?..bad gauge, bad sending unit, plugged radiator(inside), water pump going/gone bad, wrong rad. pressure cap...??? Good luck!
