Won't start now.
Dennis
07-07-2004 20:04:36
Bought a Massey Ferguson 1120 in need of work. Its 7 years old and I payed $700. When I bought this tractor it was thought to be in need of a new injection pump. It started and blew out lots of black smoke. Fuel should be white, right? It was supposed to have new rings in it. I think any mechanical work done before I bought it could be suspect. After I got it home, I could not get it to start. I disconnected the injector lines at the pump and it puts out a small amount of fuel on the center line, no pressure and thats it. I tried spraying WD40 in the intake and it would not fire on that, also tried a little ether, it almost fires on both but will not run. Got any ideas? Thanks, Dennis
Oldfarmboy Jim
07-07-2004 22:37:05
 Re: Won't start now. in reply to Dennis, 07-07-2004 20:04:36
Have you bled the fuel system following the manufacturer's directions? Relaced the fuel filters? Drained the fuel tank at the low point to get rid of water? Best bet is to obtain the operator's manual and go from there. Good luck. Jim
