65 MF
homer long
07-07-2004 10:55:20
My 65 has multi power and shifts into high range by its self and then you have to move lever up and down manuaully to get it to release so you can change gears or to just slow down ground speed when baleing seems to be worst when using romote hyd. for haybine I have changed trans/hyd.oil and cleaned internal filter screen which was clean as a whistle just rebuilt clutch 2 years ago so oil was only 2yrs old NO WATER but when removing rear drain plug. There was a 1/4" x 1 1/2" long bolt stuck to the magnetic plug. So where or whats bolted down inside with this size bolt. She just started this all at once no problems until half way thru first mowing of 10 acres
sibby(Aus)
07-07-2004 19:53:48
 Re: 65 MF in reply to homer long, 07-07-2004 10:55:20
homer, Bolt sounds like it could be off the end of your hydraulic lift pump maybe, that holds the filter housing. Not sure if your M/P problem is in the linkage or oil pressure problem. cheers.
