MF65 TRANSMISSION FLUID LEAK
RICHARD FALLS
07-05-2004 14:00:45
HELLO I NEED HELP FINDING WHY I HAVE A HOLE IN THE BOTTOM OF MY TRANSMISSION CASE AND WHY I AM LOOSEING ALL MY FLUID THROUGH THAT HOLE. THE HOLE IS ABOUT 3 INCHES TOWARDS THE FRONT OF THE TRACTOR FROM THE DRAIN PLUG. ITS NOT THREADED SO WHAT IS IT FOR? THANKS FOR ANY HELP RICH
smokey
07-06-2004 02:46:19
 Re: MF65 TRANSMISSION FLUID LEAK in reply to RICHARD FALLS, 07-05-2004 14:00:45
Check Big Deans site. He covers this in the buying a tractor guide. The hole should have a split pin in it to stop dirt etc. He also covers what is involved in splitting an MF tractor.
Tommy D6-8U
07-05-2004 14:14:26
Rcihard,
That hole is there to drain away any motor oil, transmission oil, or water that may collect in the clutch housing. In all likelihood, you have a seal leaking in the front of the transmission. An engine oil leak would have to be very bad to leak that far back. The tractor would have to be split in two to repair any of it though.
Tommy
RICHARD FALLS
07-05-2004 15:08:42
 Re: Re: MF65 TRANSMISSION FLUID LEAK in reply to Tommy D6-8U, 07-05-2004 14:14:26
THANKS TOMMY FOR THE INFO. NOW I KNOW WHAT IS HAPPING AND WHAT I HAVE TO DO TO GET IT FIXED, THANKS AGAIN.
RICHARD
Bob
07-05-2004 16:49:06
 Re: Re: Re: MF65 TRANSMISSION FLUID LEAK in reply to RICHARD FALLS, 07-05-2004 15:08:42
Does this tractor have Muti-Power?
sibby(Aus)
07-05-2004 19:55:24
 Re: Re: Re: Re: MF65 TRANSMISSION FLUID LEAK in reply to Bob, 07-05-2004 16:49:06
Richard, Does the oil look , smell or feel like trans oil or engine oil, either way it will have to be split like tommy says. cheers, sibby.
RICHARD FALLS
07-06-2004 16:43:26
 Re: Re: Re: Re: Re: MF65 TRANSMISSION FLUID LEAK in reply to sibby(Aus), 07-05-2004 19:55:24
HELLO EVERYONE. IT DOES HAVE MULTI-POWER AND IT IS TRANSMISSION FLUID. I HAVE A MECHANIC PICKED TO DO THE JOB. THANKS TO ALL FOR ALL THE INFO. RICH
