MF202 timing
Karl
07-05-2004 08:16:00
I just installed an electronic ignition in my '63 MF 202. After I installed the unit I timed the engine by ear and it runs okay but, I'd really like to time it properly. When I try to shine my timing light through the hole in the bell housing I can't get the light in there and see the timing marks at the same time. The hole is just too tight. Is there any secret or trick to this that I'm missing? The engine is a Continential Z134.
Thanks.
Karl
07-18-2004 14:14:56
 Re: MF202 timing in reply to Karl, 07-05-2004 08:16:00
The whole job went pretty smoothly. The only issue was deciding which dist. I had on my tractor. There is about 8 different possibilities. I finally removed mine and found the tag on the backside of the distributor. The guy I dealt with at Retro Rockets, Carl,was great at matching the unit I needed. Their web site is... Link
Todd
07-16-2004 20:19:14
Karl, I also have a 63 202 and I am considering installing electronic ignition.Any pointers or difficulties other than the timing light?
Jack
07-05-2004 19:13:12
Karl, I had the same problem with my 204! I used a mirror to bounce the light off of into the hole. It worked for me.
